跳转到主内容
ASUS TUF Gaming FX505DY Back Case Replacement
你所需要的
  1. ASUS TUF Gaming FX505DY Back Case Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Back Case Replacement: 步骤 2 中的图像 1,2 ASUS TUF Gaming FX505DY Back Case Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Back Case Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505DY Back Case Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Back Case Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505DY Back Case Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 33
总计 968
