此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
转到步骤 1 ↓本指南用于更换 ASUS TUF Gaming FX505DY 的电池,这是一款 3 芯 48 瓦时锂离子内置电池。
尽管该设备具备 MIL-STD-810G 军规认证,但剧烈撞击或穿刺仍可能损坏甚至损毁电池。电池也可能因为过热或在长期使用后无法充电而失效。故障电池 会导致电池续航时间变短或根本无法使用、无法充电,甚至损坏设备。请先查看故障排除页面,确认并非其他问题所致。
请留意电池是否出现损坏迹象,包括鼓包、开裂、漏液或烧焦。如果电池已经或疑似受损,请穿着防火或天然纤维材质的衣物进行维修。确保工作区域远离易燃材料,并随手准备好功能正常的 B 类灭火器或其他合适的灭火介质。锂离子电池起火时,请勿用水灭火。
在开始之前,请务必彻底关闭设备电源,并拔下所有充电器和外设。
你所需要的
工具
Spudger4.9
要重新组装设备,请按相反顺序执行这些说明。
3等其他人完成本指南。
3指南评论
What Is the serial number of the battery ?
Can anyone tell me where to purchase a replacement battery? I have contacted the manufacturer who will not provide any information other than the usual, "Drop off or post your laptop to a service centre near you. Do not attempt to change the battery yourself. For your details of your nearest repair centre please provide your location".
Hey there, thanks for your question! Batteries can be purchased from online retailers, such as Amazon. Before you purchase a battery, make sure you have written down, photographed, or removed the old battery for reference. Make sure the connector, voltage, and shape match. Model numbers shouldn't change but can, and capacity (in Wh or mAh) can vary from the OEM version. Check the return policy just in case, and remember that if purchasing a 3rd-party model there may be a higher chance for a defect.
