跳转到主内容
ASUS T300LA-US51T SSD Replacement
你所需要的
    • METHOD 1: Use a plastic pry tool to pop the back of the tablet off. Be careful the aluminum back is attached via plastic hooks.
    • METHOD 2: Access by removing the screen (suggested by Quantum Byte)
    • If like me you are unable to find a gap to detach the aluminium back from the frame so instead I tried accessing by removing the screen using a sharp tool (a metal blade such as a Stanley knife or a flat-ended spudger) as in the video (not my work).
    • Unfortunately, this is not as easy as in the video as the entire outer edge seems to be glued. Furthermore, the screen cracks v. easily. Since my screen was already damaged, I ended up breaking up and tearing the screen off. I am perhaps not best to advise on this method.
    • I suggest using a hair dryer/ heat gun to melt the glue sufficiently to make the screen detach.
  1. ASUS T300LA-US51T SSD Replacement: 步骤 2 中的图像 1,2 ASUS T300LA-US51T SSD Replacement: 步骤 2 中的图像 2,2
    • The battery is attached via 6 screws. They are clearly marked with location and screw size.
  2. ASUS T300LA-US51T SSD Replacement: 步骤 3 中的图像 1,1
    • The SSD is a M.2 NGFF style with a size of 80mm. The label states 3.3v 2A. If replaced with a lower power drive battery life might increase.
    • Unscrew the single screw on the end of the drive. Undo the tabs on the ribbon cable above it and take the ribbon out.
    • Remove the drive and replace with a larger new one.
结论
Be careful to place everything back the way that you found it.
4等其他人完成本指南。
Sasa Macura
于08/05/14注册
177 声望
创作了2篇指南
一条评论
Note that this guide does not work for the Asus T300 Chi which has an eMMC solid state drive soldered directly to the motherboard - you will need an eMMC reader and skill in removing soldered components to do this. Recommend taking to a data recovery professional in this case
Quantum Byte - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 54
总计 17,078
