跳转到主内容
ASUS ROG Zephyrus M15GU205L Display Cable Replacement
你所需要的
  1. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: 步骤 1 中的图像 1,2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: 步骤 2 中的图像 1,2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: 步骤 3 中的图像 1,1
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: 步骤 4 中的图像 1,2 ASUS ROG Zephyrus M15GU205L Display Cable Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the computer.
  6. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Display Cable: 步骤 6 中的图像 1,1
    • Once the back has been removed, locate this connection cable.
    • Check to see if the connector is in the pin slot; if not, locate the connector.
  7. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: 步骤 7 中的图像 1,1
    • If the connection is loose, connect the pins into the slot.
    • Once the connector is connected, do these steps in reverse.
结论
Yahir Donis
于09/07/23注册
339 声望
创作了2篇指南
团队
Gateway, Team 69-69, Gonzalez Fall 2023 Gateway, Team 69-69, Gonzalez Fall 2023 的会员
GCC-GONZALEZ-F23S69G69
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 32
总计 198
