跳转到主内容
ASUS ROG Strix GL503VD-DB71 Fan Replacement
你所需要的
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: 步骤 1 中的图像 1,3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: 步骤 1 中的图像 2,3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: 步骤 1 中的图像 3,3
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: 步骤 2 中的图像 1,3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 步骤 2 中的图像 2,3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 步骤 2 中的图像 3,3
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: 步骤 3 中的图像 1,3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 步骤 3 中的图像 2,3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
结论
另外一个人完成了本指南。
2条评论
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - 回复
WTF i can find a 12 V for my GL503V
mrparisalexandre - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 27
总计 4,535
