跳转到主内容
ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement
你所需要的
  1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement, Internal Hard Drive: 步骤 1 中的图像 1,1
    • Remove the six screws on the back of the laptop using a Phillips screwdriver.
    • Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
  2. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 步骤 2 中的图像 1,2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Locate the metal hard drive bay in the bottom left corner of the laptop.
    • Remove the two black screws securing the metal hard drive to the plastic.
    • Pull the tab to the right and slide to unseat the hard drive bay, then lift out.
  3. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 步骤 3 中的图像 1,2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the two screws on the sides of the hard drive panel, shown circled. Repeat for the other side.
    • Replace the hard drive.
结论
3等其他人完成本指南。
Logan Smith
于01/25/17注册
783 声望
创作了4篇指南
团队
Cal Poly, Team 8-3, Banghart Winter 2017 Cal Poly, Team 8-3, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 961
