跳转到主内容
ASUS ROG G46VW Motherboard Replacement
你所需要的
  1. ASUS ROG G46VW Motherboard Replacement, RAM: 步骤 1 中的图像 1,2 ASUS ROG G46VW Motherboard Replacement, RAM: 步骤 1 中的图像 2,2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Motherboard Replacement: 步骤 3 中的图像 1,2 ASUS ROG G46VW Motherboard Replacement: 步骤 3 中的图像 2,2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Motherboard Replacement: 步骤 4 中的图像 1,1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Motherboard Replacement: 步骤 5 中的图像 1,1
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Motherboard Replacement, Speaker Cover: 步骤 6 中的图像 1,1
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Motherboard Replacement, Keyboard: 步骤 8 中的图像 1,1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Motherboard Replacement: 步骤 10 中的图像 1,1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Motherboard Replacement: 步骤 11 中的图像 1,1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Motherboard Replacement: 步骤 12 中的图像 1,2 ASUS ROG G46VW Motherboard Replacement: 步骤 12 中的图像 2,2
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Motherboard Replacement, Screen: 步骤 13 中的图像 1,2 ASUS ROG G46VW Motherboard Replacement, Screen: 步骤 13 中的图像 2,2
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Motherboard Replacement: 步骤 14 中的图像 1,1
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Motherboard Replacement: 步骤 16 中的图像 1,1
    • Gently pull the white connector until it comes loose.
  17. ASUS ROG G46VW Motherboard Replacement, Indicator Lights: 步骤 17 中的图像 1,1
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  18. ASUS ROG G46VW Motherboard Replacement: 步骤 18 中的图像 1,1
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  19. ASUS ROG G46VW Motherboard Replacement: 步骤 19 中的图像 1,1
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
  20. ASUS ROG G46VW Motherboard Replacement, Motherboard: 步骤 20 中的图像 1,1
    • Locate and remove the screws.
    • Removing the screws allows you to lift up the motherboard
  21. ASUS ROG G46VW Motherboard Replacement: 步骤 21 中的图像 1,1
    • After lifting the motherboard up you can replace any component on it, such as the fans.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 18
总计 1,953
