跳转到主内容
ASUS R554L Battery Replacement
你所需要的
  1. ASUS R554L Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: 步骤 2 中的图像 1,3 ASUS R554L Battery Replacement: 步骤 2 中的图像 2,3 ASUS R554L Battery Replacement: 步骤 2 中的图像 3,3
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: 步骤 3 中的图像 1,3 ASUS R554L Battery Replacement: 步骤 3 中的图像 2,3 ASUS R554L Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: 步骤 4 中的图像 1,3 ASUS R554L Battery Replacement: 步骤 4 中的图像 2,3 ASUS R554L Battery Replacement: 步骤 4 中的图像 3,3
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: 步骤 5 中的图像 1,3 ASUS R554L Battery Replacement: 步骤 5 中的图像 2,3 ASUS R554L Battery Replacement: 步骤 5 中的图像 3,3
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: 步骤 6 中的图像 1,2 ASUS R554L Battery Replacement: 步骤 6 中的图像 2,2
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
结论
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
另外一个人完成了本指南。
Joshua Chavez
于01/31/22注册
160 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-49, Briggs Spring 2022 CSU Los Angeles, Team 4-49, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S4G49
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 113
总计 3,749
