跳转到主内容
加入维修社区 - 创建账户
ASUS Q536F Motherboard Replacement
你所需要的
  1. ASUS Q536F Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 ASUS Q536F Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Motherboard Replacement, Battery: 步骤 2 中的图像 1,2 ASUS Q536F Motherboard Replacement, Battery: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
    • Detach the battery cable from the motherboard using a pair of tweezers.
  3. ASUS Q536F Motherboard Replacement: 步骤 3 中的图像 1,3 ASUS Q536F Motherboard Replacement: 步骤 3 中的图像 2,3 ASUS Q536F Motherboard Replacement: 步骤 3 中的图像 3,3
    • Unhinge the fan cable using your fingers or a pair of tweezers.
    • Remove the battery from its slot.
    • There should be no resistance from any cable wiring at this point. If there happens to be resistance, make sure to double check and confirm nothing is being pulled.
  4. ASUS Q536F Motherboard Replacement, Fan: 步骤 4 中的图像 1,2 ASUS Q536F Motherboard Replacement, Fan: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
    • Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
    • Warped Screw
    • Heatsink shown has warped screw, so unable to remove
  5. ASUS Q536F Motherboard Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect white and black antennae cables.
    • Using tweezers for this would be helpful.
  6. ASUS Q536F Motherboard Replacement: 步骤 6 中的图像 1,2 ASUS Q536F Motherboard Replacement: 步骤 6 中的图像 2,2
    • Disconnect fan cables pulling outwards as shown.
  7. ASUS Q536F Motherboard Replacement: 步骤 7 中的图像 1,3 ASUS Q536F Motherboard Replacement: 步骤 7 中的图像 2,3 ASUS Q536F Motherboard Replacement: 步骤 7 中的图像 3,3
    • Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
    • The fan can be removed without removing the heatsink, although it may be easier to remove.
  8. ASUS Q536F Motherboard Replacement, Hard Drive: 步骤 8 中的图像 1,2 ASUS Q536F Motherboard Replacement, Hard Drive: 步骤 8 中的图像 2,2
    • Disconnect the white ribbon cable from the connection lever using a Jimmy.
  9. ASUS Q536F Motherboard Replacement: 步骤 9 中的图像 1,2 ASUS Q536F Motherboard Replacement: 步骤 9 中的图像 2,2
    • Using the Jimmy, lift the hard drive out of its slot.
  10. ASUS Q536F Motherboard Replacement, SSD: 步骤 10 中的图像 1,1
    • Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
  11. ASUS Q536F Motherboard Replacement: 步骤 11 中的图像 1,1
    • Pull the SSD out of its slot.
  12. ASUS Q536F Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,2 ASUS Q536F Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws that secure the motherboard.
  13. ASUS Q536F Motherboard Replacement: 步骤 13 中的图像 1,1
    • Using a Jimmy, pull up on the power cable.
  14. ASUS Q536F Motherboard Replacement: 步骤 14 中的图像 1,3 ASUS Q536F Motherboard Replacement: 步骤 14 中的图像 2,3 ASUS Q536F Motherboard Replacement: 步骤 14 中的图像 3,3
    • Using the Jimmy, lift up on both ribbon cable clamps, releasing the connection point, just like in step 8.
结论
Adra Ledward
于09/07/23注册
557 声望
创作了5篇指南
团队
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 的会员
GCC-GONZALEZ-F23S88G8
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 609
