跳转到主内容
ASUS Q524U Hard Drive Replacement
你所需要的
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: 步骤 2 中的图像 1,3 ASUS Q524U Hard Drive Replacement: 步骤 2 中的图像 2,3 ASUS Q524U Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: 步骤 6 中的图像 1,2 ASUS Q524U Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
终点
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 47
总计 3,235
