跳转到主内容
ASUS Q405U Wifi Card Replacement
你所需要的
  1. ASUS Q405U Wifi Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Wifi Card Replacement: 步骤 2 中的图像 1,1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Wifi Card Replacement: 步骤 3 中的图像 1,3 ASUS Q405U Wifi Card Replacement: 步骤 3 中的图像 2,3 ASUS Q405U Wifi Card Replacement: 步骤 3 中的图像 3,3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Wifi Card Replacement, Battery: 步骤 4 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  5. ASUS Q405U Wifi Card Replacement: 步骤 5 中的图像 1,1
    • Once all screws are removed, lift the battery out from the base of the computer.
  6. ASUS Q405U Wifi Card Replacement, Wifi Card: 步骤 6 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the 0.8 mm screw securing the Wi-Fi card to the device.
结论
团队
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S2G8
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 361
