简介
The hard drive, responsible for storing all your important files. Without a hard drive, your computer would have nothing to operate off of. It would be a machine without code. Therefore, issues with it tend to be very serious. Things such as corruption can cause important files to be lost or damaged. That’s why this guide will be very helpful, in the event that you need to replace the hard drive of your ASUS Q405U.
你所需要的
Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
Remove the narrow strip of tape to the left of the hard drive.
Remove the five screws holding the caddy in.
Lift the hard drive slight;y and slide it to the right to remove it from its socket.
另外一个人完成了本指南。
