跳转到主内容
ASUS Q400A-BHI7N03 Screen Replacement
你所需要的
  1. ASUS Q400A-BHI7N03 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Flip the laptop on its back side with the battery facing toward you.
    • Slide the tabs with lock/unlock symbol, to the unlock position.
    • Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Screen Replacement: 步骤 2 中的图像 1,1
    • Lift the two black plastic circles off the screen using the plastic spudger.
    • Unscrew the two 8mm Phillips #0 screws.
  3. ASUS Q400A-BHI7N03 Screen Replacement: 步骤 3 中的图像 1,1
    • Pry the front edges of the screen using the spudger.
  4. ASUS Q400A-BHI7N03 Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the four black 8mm Phillips #0 screws and set them aside.
  5. ASUS Q400A-BHI7N03 Screen Replacement: 步骤 5 中的图像 1,1
    • Pry the LCD from the front frame.
  6. ASUS Q400A-BHI7N03 Screen Replacement: 步骤 6 中的图像 1,1
    • Pull the gold ribbon cable to disconnect the screen from the laptop.
结论
3等其他人完成本指南。
Wan Ahmad Aiman
于10/31/18注册
403 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Harley Fall 2018 IUPUI, Team S1-G3, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S1G3
3 名成员
创作了2篇指南
一条评论
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
Daniel Ventura Avalos - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 556
