跳转到主内容
ASUS Q400A-BHI7N03 Optical Drive Replacement
你所需要的
  1. ASUS Q400A-BHI7N03 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 Optical Drive Replacement: 步骤 3 中的图像 1,2 ASUS Q400A-BHI7N03 Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
  4. ASUS Q400A-BHI7N03 Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Locate and remove the 8mm PH0 screw near the middle of the laptop.
  5. ASUS Q400A-BHI7N03 Optical Drive Replacement: 步骤 5 中的图像 1,2 ASUS Q400A-BHI7N03 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Use a metal opening tool to remove the L-shaped, plastic cover.
    • To avoid breaking the plastic, alternate the sides where you pry.
  6. ASUS Q400A-BHI7N03 Optical Drive Replacement: 步骤 6 中的图像 1,2 ASUS Q400A-BHI7N03 Optical Drive Replacement: 步骤 6 中的图像 2,2
    • On the left side of the section, there is a metal tab. Using a metal opening tool, push the tab as far as possible to the left.
    • Only push on the metal tab so you do not damage the surrounding plastic.
    • Once the optical drive is sticking out of the left side of the laptop, slide it smoothly out of its slot.
结论
Matthew Gold
于01/19/17注册
401 声望
创作了4篇指南
团队
UC Davis, Team 1-4, Rodger Winter 2017 UC Davis, Team 1-4, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G4
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 491
