跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Keys can be dirty and unresponsive. Use this guide to clean under or replace keys.
配件
没有特定配件。
  1. To remove a key, insert the opening tool in the small gap at the top right corner of the key.
    • To remove a key, insert the opening tool in the small gap at the top right corner of the key.
    • Pry off the key by pulling the tool up until the key pops off.
    • If the key is still connected at the bottom, wiggle the key from side to side until it comes off.
  2. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  3. If there is dirt under the key, use an air canister to clean it up. Do not use any liquids to clean.
    • If there is dirt under the key, use an air canister to clean it up.
    • Do not use any liquids to clean.
  4. To put the key back in, line it up with the area it came from and push it back in. There will be an audible click when it is correctly inserted.
    • To put the key back in, line it up with the area it came from and push it back in. There will be an audible click when it is correctly inserted.
终点
Matthew Gold
于2017年01月19日注册
401 信誉积分
创作了4篇指南
团队
UC Davis, Team 1-4, Rodger Winter 2017 UC Davis, Team 1-4, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G4
5 名成员
创作了4篇指南
Some keys seem to also have a metal bracket under them that need to be strung in when re-inserting the key. Maybe add some instruction for that.
Kevin Low - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 7
总计 212
