跳转到主内容
ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement
你所需要的
  1. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 2 中的图像 1,2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 3 中的图像 1,1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 4 中的图像 1,1
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 5 中的图像 1,2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 5 中的图像 2,2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Power & Volume Button PCB Board: 步骤 6 中的图像 1,1
    • Remove the screw holding the Power chip in place and remove it using a Phillips head #0 screw driver.
    • Screw length is 0.5 cm in length and 0.5 cm in diameter
  7. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 7 中的图像 1,3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 7 中的图像 2,3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: 步骤 7 中的图像 3,3
    • Locate the ribbon connector connecting the power chip to the mother board.
    • Simply lift up the black component and the ribbon connector should be released, then the power chip should pop out easily.
    • Discard of the old power chip properly.
结论
Scott Santiago
于10/17/17注册
534 声望
创作了5篇指南
团队
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 UMass Dartmouth, Team S1-G1, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 638
