当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
Remove the six screws holding in the battery with a Phillips #0 screwdriver.
Once battery is lifted out and removed, proper dispose of the old battery.
Each screw is 0.5 cm in length and 0.5 cm in diameter.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
