跳转到主内容
ASUS Q324UA-BHI7T17 Battery Replacement
你所需要的
  1. ASUS Q324UA-BHI7T17 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 Battery Replacement: 步骤 2 中的图像 1,2 ASUS Q324UA-BHI7T17 Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Battery Replacement: 步骤 3 中的图像 1,1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 Battery Replacement: 步骤 5 中的图像 1,2 ASUS Q324UA-BHI7T17 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
结论
Scott Santiago
于10/17/17注册
534 声望
创作了5篇指南
团队
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 UMass Dartmouth, Team S1-G1, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G1
3 名成员
创作了5篇指南
3条评论
The screws in this laptop are *not* all the same length. Unfortunately, I only kept track of some of them as I didn’t notice that they weren’t all the same until I had most of them out. I know that two of the longer screws go in the back between the back feet, but I’m not 100% sure of the others.
Scott Gartner - 回复
where can i purchase this battery?
eddygblk - 回复
I removed the cover successfully (including noting where the long and short screws are located) but cannot get the #0 Phillips screwdriver to fit into those tiny cross shaped slots in the screws holding the battery in. It seems to be too big or the wrong shape, and I am really concerned about stripping the heads by tying to force it too much. Maybe a small regular flat head that will fit into the grooves?
Gil Hutchinson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,663
