简介
This is a guide to replace the motherboard of your ASUS Q302L laptop. You may need to replace your motherboard if you determine that is the faulty component of your laptop. The first thing you’ll need is a grounding strap and grounding mat. These are to ensure that you do not damage your new motherboard or other components on your laptop while replacing the motherboard. You will also need a small Phillips #00 screwdriver, a small flat head screwdriver, and a prying tool.
你所需要的
Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
Peel back the adhered strip to expose the black and white connections.
Pop the connections off the fixtures.
2等其他人完成本指南。
