跳转到主内容
ASUS Q302L Display Replacement
你所需要的
  1. ASUS Q302L Display Replacement, Back Case: 步骤 1 中的图像 1,1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Display Replacement: 步骤 2 中的图像 1,3 ASUS Q302L Display Replacement: 步骤 2 中的图像 2,3 ASUS Q302L Display Replacement: 步骤 2 中的图像 3,3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Display Replacement: 步骤 3 中的图像 1,1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Display Replacement, Battery: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Display Replacement: 步骤 5 中的图像 1,3 ASUS Q302L Display Replacement: 步骤 5 中的图像 2,3 ASUS Q302L Display Replacement: 步骤 5 中的图像 3,3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Display Replacement: 步骤 6 中的图像 1,2 ASUS Q302L Display Replacement: 步骤 6 中的图像 2,2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Display Replacement, Display: 步骤 7 中的图像 1,2 ASUS Q302L Display Replacement, Display: 步骤 7 中的图像 2,2
    • Use a Phillips #00 screw driver to remove the five 10mm screws at the hinges.
  8. ASUS Q302L Display Replacement: 步骤 8 中的图像 1,3 ASUS Q302L Display Replacement: 步骤 8 中的图像 2,3 ASUS Q302L Display Replacement: 步骤 8 中的图像 3,3
    • Peel back the tape and remove the two connectors.
  9. ASUS Q302L Display Replacement: 步骤 9 中的图像 1,2 ASUS Q302L Display Replacement: 步骤 9 中的图像 2,2
    • Pull up on the black tab to remove the connector that connects to the motherboard.
    • Unplug the hard drive cable from the hard drive.
    • Carefully remove the cables from the track that they run through.
  10. ASUS Q302L Display Replacement: 步骤 10 中的图像 1,2 ASUS Q302L Display Replacement: 步骤 10 中的图像 2,2
    • Carefully remove the display from the rest of the laptop.
结论
另外一个人完成了本指南。
Nicholas Lozier
于04/01/19注册
290 声望
创作了2篇指南
团队
IUPUI, Team S2-G4, Harley Spring 2019 IUPUI, Team S2-G4, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S2G4
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,141
