跳转到主内容
加入维修社区 - 创建账户
ASUS Q302L Battery Replacement
你所需要的
  1. ASUS Q302L Battery Replacement, Back Case: 步骤 1 中的图像 1,1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Battery Replacement: 步骤 2 中的图像 1,3 ASUS Q302L Battery Replacement: 步骤 2 中的图像 2,3 ASUS Q302L Battery Replacement: 步骤 2 中的图像 3,3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Battery Replacement: 步骤 3 中的图像 1,1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Battery Replacement: 步骤 5 中的图像 1,3 ASUS Q302L Battery Replacement: 步骤 5 中的图像 2,3 ASUS Q302L Battery Replacement: 步骤 5 中的图像 3,3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Battery Replacement: 步骤 6 中的图像 1,2 ASUS Q302L Battery Replacement: 步骤 6 中的图像 2,2
    • Once the screws and connector are removed, simply pull out the battery from its place.
结论
3等其他人完成本指南。
khalifa
于03/02/17注册
110 声望
撰写一个指南
团队
USF Tampa, Team S13-G4, Cagle Spring 2017 USF Tampa, Team S13-G4, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G4
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 37
总计 6,429
