简介
This guide will walk you through the steps necessary to replace the heat sink and fan assembly in the ASUS Portable AiO PT2001. No special skills are required.
The only tool you need is a Phillips screwdriver.
你所需要的
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
Remove the tape attached to the heat sink and the metal enclosure.
Lift the metal enclosure off.
