跳转到主内容
ASUS Portable AiO PT2001 Back Panel Replacement
你所需要的
  1. ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,3 ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,3 ASUS Portable AiO PT2001 Back Panel Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. ASUS Portable AiO PT2001 Back Panel Replacement: 步骤 2 中的图像 1,3 ASUS Portable AiO PT2001 Back Panel Replacement: 步骤 2 中的图像 2,3 ASUS Portable AiO PT2001 Back Panel Replacement: 步骤 2 中的图像 3,3
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. ASUS Portable AiO PT2001 Back Panel Replacement: 步骤 3 中的图像 1,3 ASUS Portable AiO PT2001 Back Panel Replacement: 步骤 3 中的图像 2,3 ASUS Portable AiO PT2001 Back Panel Replacement: 步骤 3 中的图像 3,3
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
结论
4等其他人完成本指南。
团队
Cal Poly, Team S17-G5, Livingston Spring 2018 Cal Poly, Team S17-G5, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G5
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,218
