跳转到主内容
ASUS Padfone X mini Station Battery Replacement
你所需要的
  1. ASUS Padfone X mini Station Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Battery Replacement: 步骤 2 中的图像 1,2 ASUS Padfone X mini Station Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Battery Replacement: 步骤 3 中的图像 1,3 ASUS Padfone X mini Station Battery Replacement: 步骤 3 中的图像 2,3 ASUS Padfone X mini Station Battery Replacement: 步骤 3 中的图像 3,3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
结论
Alexzander Pastore
于10/26/18注册
389 声望
创作了3篇指南
团队
UMass Dartmouth, Team S2-G7, Peak Fall 2018 UMass Dartmouth, Team S2-G7, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 518
