跳转到主内容
ASUS PadFone X Vibration Motor Replacement
你所需要的
  1. ASUS PadFone X Vibration Motor Replacement, Vibration Motor: 步骤 1 中的图像 1,2 ASUS PadFone X Vibration Motor Replacement, Vibration Motor: 步骤 1 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Vibration Motor Replacement: 步骤 2 中的图像 1,2 ASUS PadFone X Vibration Motor Replacement: 步骤 2 中的图像 2,2
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Vibration Motor Replacement: 步骤 3 中的图像 1,2 ASUS PadFone X Vibration Motor Replacement: 步骤 3 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Vibration Motor Replacement: 步骤 4 中的图像 1,1
    • Using a spudger, pry the vibration motor connector from the motherboard.
  5. ASUS PadFone X Vibration Motor Replacement: 步骤 5 中的图像 1,1
    • Gently pry the vibration motor upwards using the spudger.
    • The vibration motor is held down by some adhesive, force might be needed to remove it.
结论
Ryan
于05/14/12注册
223 声望
创作了2篇指南
团队
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G4
4 名成员
创作了5篇指南
一条评论
That is not the speaker, that is the motor for the vibrate functions...
The speaker is located in the plastic back of the housing near the camera hole.
tee1331 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 1,307
