跳转到主内容
ASUS PadFone X Station Docking Connector Replacement
你所需要的
  1. ASUS PadFone X Station Docking Connector Replacement, Back Cover: 步骤 1 中的图像 1,2 ASUS PadFone X Station Docking Connector Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Docking Connector Replacement, USB connector: 步骤 2 中的图像 1,2 ASUS PadFone X Station Docking Connector Replacement, USB connector: 步骤 2 中的图像 2,2
    • Locate the CON101
    • The white sticker indicates water exposure. White=none, Red=Exposure
  3. ASUS PadFone X Station Docking Connector Replacement, Remove two Phillips screws: 步骤 3 中的图像 1,1
    • Remove two Phillips screws
  4. ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: 步骤 4 中的图像 1,2 ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: 步骤 4 中的图像 2,2
    • Locate P92L on CON1504
    • Gently peel back and remove plastic tape
  5. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: 步骤 5 中的图像 1,3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: 步骤 5 中的图像 2,3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: 步骤 5 中的图像 3,3
    • Gently Pull P92L With Fingers From CON1504
  6. ASUS PadFone X Station Docking Connector Replacement, Identification of Antenna Wires: 步骤 6 中的图像 1,1
    • These are the antenna wires.
    • Trace these wires to locate the two antennas.
  7. ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: 步骤 7 中的图像 1,2 ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: 步骤 7 中的图像 2,2
    • Locate the two antennas
    • Desolder the two antenna wires
结论
另外一个人完成了本指南。
Daniel
于10/07/14注册
338 声望
创作了2篇指南
团队
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S7G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,460
