跳转到主内容
ASUS PadFone X Rear Facing Camera Replacement
你所需要的
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: 步骤 1 中的图像 1,2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: 步骤 1 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 步骤 2 中的图像 1,3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 步骤 2 中的图像 2,3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: 步骤 2 中的图像 3,3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: 步骤 3 中的图像 1,2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: 步骤 3 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: 步骤 4 中的图像 1,1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: 步骤 6 中的图像 1,1
    • Once the camera has been pulled out, replace the old camera with a new camera.
结论
nestor
于10/07/14注册
101 声望
撰写一个指南
团队
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 546
