跳转到主内容
ASUS PadFone X Rear Case Replacement
你所需要的
  1. ASUS PadFone X Rear Case Replacement, Remove the back panel.: 步骤 1 中的图像 1,2 ASUS PadFone X Rear Case Replacement, Remove the back panel.: 步骤 1 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Case Replacement, Antenna replacement: 步骤 2 中的图像 1,1
    • Replace the back cover with the new one; the antenna is integrated with the back panel.
结论
John Kue
于10/07/14注册
379 声望
创作了2篇指南
团队
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 980
