跳转到主内容
ASUS PadFone X Power and Volume Buttons Replacement
你所需要的
  1. ASUS PadFone X Power and Volume Buttons Replacement, Power and Volume Buttons: 步骤 1 中的图像 1,1
    • Pry off the back cover with the blue plastic opening tool.
    • Removing the cover may require a bit of force.
  2. ASUS PadFone X Power and Volume Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Power and Volume Buttons Replacement: 步骤 3 中的图像 1,1
    • Once the screws are removed, the mid-frame can be lifted off of the phone.
  4. ASUS PadFone X Power and Volume Buttons Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Grasp the button strip with tweezers.
    • Pull the buttons upwards gently. The buttons should remove easily.
  5. ASUS PadFone X Power and Volume Buttons Replacement: 步骤 5 中的图像 1,1
    • Use the blue plastic opening tool to disconnect the orange sensor strip.
    • Applying too much force may damage the connector.
  6. ASUS PadFone X Power and Volume Buttons Replacement: 步骤 6 中的图像 1,1
    • Grasp the sensor with the tweezers.
    • Pull outwards away from the phone.
    • The sensor is held on by adhesive. You will need to apply some force when removing.
结论
团队
IUPUI, Team 2-1, Baechle Spring 2017 IUPUI, Team 2-1, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S2G1
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 267
