跳转到主内容
加入维修社区 - 创建账户
ASUS PadFone X Battery Replacement
你所需要的
  1. ASUS PadFone X Battery Replacement, Remove the back panel.: 步骤 1 中的图像 1,2 ASUS PadFone X Battery Replacement, Remove the back panel.: 步骤 1 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Battery Replacement, Remove the screws.: 步骤 2 中的图像 1,2 ASUS PadFone X Battery Replacement, Remove the screws.: 步骤 2 中的图像 2,2
    • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: 步骤 3 中的图像 1,2 ASUS PadFone X Battery Replacement, Remove the Mid-Frame: 步骤 3 中的图像 2,2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: 步骤 4 中的图像 1,2 ASUS PadFone X Battery Replacement, Remove the Battery Connector: 步骤 4 中的图像 2,2
    • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Battery Replacement, Remove the battery.: 步骤 5 中的图像 1,2 ASUS PadFone X Battery Replacement, Remove the battery.: 步骤 5 中的图像 2,2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
结论
4等其他人完成本指南。
John Kue
于10/07/14注册
379 声望
创作了2篇指南
团队
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 28
总计 5,340
