跳转到主内容
ASUS MeMo Pad FHD10 Speakers Replacement
你所需要的
  1. ASUS MeMo Pad FHD10 Speakers Replacement, Battery: 步骤 1 中的图像 1,2 ASUS MeMo Pad FHD10 Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 2 中的图像 1,2 ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 2 中的图像 2,2
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 3 中的图像 1,2 ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 3 中的图像 2,2
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 4 中的图像 1,3 ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 4 中的图像 2,3 ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 4 中的图像 3,3
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 6 中的图像 1,1
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 7 中的图像 1,3 ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 7 中的图像 2,3 ASUS MeMo Pad FHD10 Speakers Replacement: 步骤 7 中的图像 3,3
    • Gently use your hands to remove the speakers.
结论
Al Muatasim
于01/20/15注册
294 声望
创作了2篇指南
团队
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 520
