简介
This guide will show you how to replace the front camera for a Asus MeMO Pad 7. If you want to take a picture from the front camera but it is not working, you can simply follow the instructions to replace and make it work again.
你所需要的
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
After removing the battery from the device, locate the volume connectors on the side of the device.
Using tweezers, carefully remove the volume connectors and place it to the side.
Flip the motherboard and find the place where the front camera connector is.
Using tweezers, carefully remove the front camera connectors and place it to the side.
