跳转到主内容
ASUS K553MA-DB01TQ Battery Replacement
你所需要的
  1. ASUS K553MA-DB01TQ Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Turn the laptop over. Using the Phillips Head 000 bit, remove the four 4.8mm screws from the bottom edge. Use the same bit to then remove the remaining six 9.5mm screws.
  2. ASUS K553MA-DB01TQ Battery Replacement: 步骤 2 中的图像 1,1
    • Using the iFixit Opening Tool, pry the keyboard off.
  3. ASUS K553MA-DB01TQ Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the keyboard from the laptop.
    • Be careful of any ribbon cables attached to the keyboard so you don't rip those out.
  4. ASUS K553MA-DB01TQ Battery Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #000, remove the four 9.5mm screws around the battery.
  5. ASUS K553MA-DB01TQ Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully disconnect the battery's 8-pin connection to the motherboard.
  6. ASUS K553MA-DB01TQ Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from the laptop.
结论
John Wengierski
于09/06/19注册
159 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 228
