跳转到主内容
ASUS K53E-BBR1 RAM Replacement
你所需要的
  1. ASUS K53E-BBR1 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 RAM Replacement: 步骤 3 中的图像 1,3 ASUS K53E-BBR1 RAM Replacement: 步骤 3 中的图像 2,3 ASUS K53E-BBR1 RAM Replacement: 步骤 3 中的图像 3,3
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 RAM Replacement, RAM: 步骤 4 中的图像 1,2 ASUS K53E-BBR1 RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
  5. ASUS K53E-BBR1 RAM Replacement: 步骤 5 中的图像 1,2 ASUS K53E-BBR1 RAM Replacement: 步骤 5 中的图像 2,2
    • Slide the back panel backwards until it stops.
    • You can now lift the panel up and out of the laptop casing.
  6. ASUS K53E-BBR1 RAM Replacement: 步骤 6 中的图像 1,3 ASUS K53E-BBR1 RAM Replacement: 步骤 6 中的图像 2,3 ASUS K53E-BBR1 RAM Replacement: 步骤 6 中的图像 3,3
    • The RAM is now visible.
    • Remove the RAM by pressing out on both tabs visible on each side of the RAM.
    • To work the tabs, take your finger tips and press outwards from the indents on the RAM.
  7. ASUS K53E-BBR1 RAM Replacement: 步骤 7 中的图像 1,2 ASUS K53E-BBR1 RAM Replacement: 步骤 7 中的图像 2,2
    • The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
    • Gently Pull the RAM out of its connector without pushing down or pulling up.
  8. ASUS K53E-BBR1 RAM Replacement: 步骤 8 中的图像 1,3 ASUS K53E-BBR1 RAM Replacement: 步骤 8 中的图像 2,3 ASUS K53E-BBR1 RAM Replacement: 步骤 8 中的图像 3,3
    • Repeat the previous two steps for the second stick of RAM.
结论
William Colangelo
于03/25/19注册
121 声望
撰写一个指南
团队
UMass Dartmouth, Team S6-G4, Peak Spring 2019 UMass Dartmouth, Team S6-G4, Peak Spring 2019 的会员
UMASSD-PEAK-S19S6G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 222
