跳转到主内容
ASUS K53E-BBR1 Keyboard Replacement
你所需要的
  1. ASUS K53E-BBR1 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Lift the monitor up so that the keyboard is visible.
    • You will notice five spots on the top of the keyboard where the iFixit opening tool should be placed.
  2. ASUS K53E-BBR1 Keyboard Replacement: 步骤 2 中的图像 1,3 ASUS K53E-BBR1 Keyboard Replacement: 步骤 2 中的图像 2,3 ASUS K53E-BBR1 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Use the iFixit opening tool on each of the designated spots to pry the keyboard apart from the palm rest.
    • You will hear a light "pop" sound each time you pry the keyboard.
    • Once the keyboard is loose, do not pull keyboard far (more than 3 inches) apart from the from the palm rest. There is a "bus" connector attached to the bottom.
  3. ASUS K53E-BBR1 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Carefully disconnect the "bus" connector from the laptop. Press on it with your thumb/index finger and slide it right along the surface of the laptop.
结论
Paulo Fortes
于03/20/19注册
147 声望
撰写一个指南
团队
UMass Dartmouth, Team S6-G4, Peak Spring 2019 UMass Dartmouth, Team S6-G4, Peak Spring 2019 的会员
UMASSD-PEAK-S19S6G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 358
