跳转到主内容
ASUS K200MA-DS01T Trackpad Replacement
你所需要的
  1. ASUS K200MA-DS01T Trackpad Replacement, Back Panel: 步骤 1 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Trackpad Replacement: 步骤 2 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement: 步骤 2 中的图像 2,2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Trackpad Replacement: 步骤 3 中的图像 1,1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Trackpad Replacement: 步骤 4 中的图像 1,3 ASUS K200MA-DS01T Trackpad Replacement: 步骤 4 中的图像 2,3 ASUS K200MA-DS01T Trackpad Replacement: 步骤 4 中的图像 3,3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Trackpad Replacement, Keyboard: 步骤 5 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement, Keyboard: 步骤 5 中的图像 2,2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Trackpad Replacement: 步骤 6 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement: 步骤 6 中的图像 2,2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Trackpad Replacement, Track Pad: 步骤 7 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement, Track Pad: 步骤 7 中的图像 2,2
    • Lift the keyboard connector from the keyboard.
  8. ASUS K200MA-DS01T Trackpad Replacement: 步骤 8 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement: 步骤 8 中的图像 2,2
    • Lift the foil sheet.
  9. ASUS K200MA-DS01T Trackpad Replacement: 步骤 9 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement: 步骤 9 中的图像 2,2
    • Eight 3 mm screws using Phillips screwdriver.
    • Be sure to remove the screw underneath the keyboard connector.
  10. ASUS K200MA-DS01T Trackpad Replacement: 步骤 10 中的图像 1,1
    • Two 2 mm screws using a Phillips #00 screwdriver.
  11. ASUS K200MA-DS01T Trackpad Replacement: 步骤 11 中的图像 1,2 ASUS K200MA-DS01T Trackpad Replacement: 步骤 11 中的图像 2,2
    • Using a plastic spudger, remove the metal plate.
  12. ASUS K200MA-DS01T Trackpad Replacement: 步骤 12 中的图像 1,3 ASUS K200MA-DS01T Trackpad Replacement: 步骤 12 中的图像 2,3 ASUS K200MA-DS01T Trackpad Replacement: 步骤 12 中的图像 3,3
    • Flip the keyboard over.
    • Using a plastic spudger, pry the track pad off the plastic piece underneath.
    • Don't be afraid to use some force in this step because the track pad and the plastic piece are glued together.
结论
Terrinda
于09/17/18注册
526 声望
创作了4篇指南
团队
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018 的会员
CSUF-BRUCE-F18S2G5
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 10
总计 106
