简介
This guide will assist in replacing the motherboard for an Asus K200MA laptop.
你所需要的
With the opening facing you, flip the laptop over and remove the following screws from the back panel:
Six 4mm Phillips screws using a Phillips #0 screwdriver.
One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
Gently pull the narrow connector away from the keyboard.
Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
Remove the following screws from the middle and far ends of the battery:
Three 4mm Phillips screws using a Phillips #0 screwdriver.
Remove the following screws:
Four 4mm Phillips screws using a Phillips #0 screwdriver.
Locate and remove the following screws on the motherboard:
Eighteen 4mm Phillips screws using a Phillips #0 screw driver.
