跳转到主内容
ASUS K200MA-DS01T Hard Drive Replacement
你所需要的
  1. ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 2 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 4 中的图像 1,3 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 4 中的图像 2,3 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: 步骤 5 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: 步骤 5 中的图像 2,2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 6 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Hard Drive Replacement, Battery: 步骤 7 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement, Battery: 步骤 7 中的图像 2,2
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 8 中的图像 1,3 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 8 中的图像 2,3 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 8 中的图像 3,3
    • Gripping the wider left section, lift the battery up and away from computer.
  9. ASUS K200MA-DS01T Hard Drive Replacement, Fan: 步骤 9 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement, Fan: 步骤 9 中的图像 2,2
    • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
  10. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Remove the following screws from the fan:
    • Two 4mm screws using a Phillips #0 screwdriver.
  11. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 11 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 11 中的图像 2,2
    • Firmly pull colored wires away from wire slot.
  12. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 12 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • After removing both the screws and color coded wires, lift fan out of place.
    • Tools such as spudgers or tweezers may be used for fan removal.
  13. ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: 步骤 13 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: 步骤 13 中的图像 2,2
    • Four 4mm Phillips screws using a Phillips #0 screwdriver.
  14. ASUS K200MA-DS01T Hard Drive Replacement: 步骤 14 中的图像 1,2 ASUS K200MA-DS01T Hard Drive Replacement: 步骤 14 中的图像 2,2
    • Remove by sliding hard driving right and away from the computer using the tag on the right side.
结论
另外一个人完成了本指南。
Terrinda
于09/17/18注册
526 声望
创作了4篇指南
团队
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018 的会员
CSUF-BRUCE-F18S2G5
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 510
