简介
This guide will demonstrate how to remove and replace the optical drive, should it ever malfunction, break, or jam.
你所需要的
即将完成!
结论
一条评论
Prior to step 1 , there is a screw that needs removed [Middle screw on the back on the side with the DVD player]
I want to point out that in order to do this step you have to remove the screw holding the CD drive in place first. On top of this if the screw is out very light pulling on the drive will remove it. There is no need for a pry tool or a needle to eject it. To make it easier on yourself I would actually do step 5 first and just be done with all the screws before you take out the CD screw (Which, by the way, step 5 is shown with the CD drive still attached and screwed in which can cause confusion and possible damage if not careful/paying attention).
Stephen Patterson - 回复
