跳转到主内容
ASUS GL752VW-DH74 Optical Drive Replacement
你所需要的
  1. ASUS GL752VW-DH74 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Begin by putting the needle into the hole in the disk tray.
    I want to point out that in order to do this step you have to remove the screw holding the CD drive in place first. On top of this if the screw is out very light pulling on the drive will remove it. There is no need for a pry tool or a needle to eject it. To make it easier on yourself I would actually do step 5 first and just be done with all the screws before you take out the CD screw (Which, by the way, step 5 is shown with the CD drive still attached and screwed in which can cause confusion and possible damage if not careful/paying attention).
    Stephen Patterson - 回复
  2. ASUS GL752VW-DH74 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to help ease out the disk drive.
  3. ASUS GL752VW-DH74 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Pull out disk tray entirely.
    I was not able to extract the DVD drive until unscrewing the .8 screw central on the back of the laptop. That one holds the DVD drive.
    Vio Belc - 回复
    You have to also remove the screw securing the DVD drive to the case.
    sgust - 回复
结论
Ralph Lopez
于10/23/17注册
202 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 的会员
UMASSD-ISAACSON-F17S1G3
3 名成员
创作了5篇指南
一条评论
Prior to step 1 , there is a screw that needs removed [Middle screw on the back on the side with the DVD player]
William Irons - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,281
