跳转到主内容
ASUS GL752VW-DH74 Battery Replacement
你所需要的
  1. ASUS GL752VW-DH74 Battery Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Begin by putting the needle into the hole in the disk tray.
    I want to point out that in order to do this step you have to remove the screw holding the CD drive in place first. On top of this if the screw is out very light pulling on the drive will remove it. There is no need for a pry tool or a needle to eject it. To make it easier on yourself I would actually do step 5 first and just be done with all the screws before you take out the CD screw (Which, by the way, step 5 is shown with the CD drive still attached and screwed in which can cause confusion and possible damage if not careful/paying attention).
    Stephen Patterson - 回复
  2. ASUS GL752VW-DH74 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to help ease out the disk drive.
  3. ASUS GL752VW-DH74 Battery Replacement: 步骤 3 中的图像 1,1
    • Pull out disk tray entirely.
    I was not able to extract the DVD drive until unscrewing the .8 screw central on the back of the laptop. That one holds the DVD drive.
    Vio Belc - 回复
    You have to also remove the screw securing the DVD drive to the case.
    sgust - 回复
  4. ASUS GL752VW-DH74 Battery Replacement, Battery: 步骤 4 中的图像 1,2 ASUS GL752VW-DH74 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the 3 small screws located underneath the disk drive.
    Step 1: Remove the optical drive.
    Stig Kjørlaug - 回复
    On the GL752VW-DH71 you have to remove the screw about 6 inches straight back from the middle of the drive in order to remove the disk drive.
    Diana Giles - 回复
    You have to remove all the screws from the next step (and the screws that are from the comments, as there are lots more than in the guide)
    Iain Halliwell - 回复
  5. ASUS GL752VW-DH74 Battery Replacement: 步骤 5 中的图像 1,2 ASUS GL752VW-DH74 Battery Replacement: 步骤 5 中的图像 2,2
    • Unscrew the nine remaining 8 mm Phillips-head screws on the back of the device.
    You neglected to mention the removal of the HDD.
    LogicalMadman - 回复
    You also have to remove all the hard drive screws and remove it from the case. Also remove the one screw near the front right.
    sgust - 回复
    There are 10 screws circled in red which need to be removed. Plus the 2 which need to be removed before the panel is removed. (already gone in this picture)
    carla8dec - 回复
    In total I removed: 10 screws from the outside of the case, 3 small screws around the optical drive, 4 screws around the hard drive (remove the hard drive after doing this), and 3 screws near the SSD and RAM which have little triangle arrows on the panel nearby. I was not apply to perform step 6 until this was done.
    snamjoshi - 回复
  6. ASUS GL752VW-DH74 Battery Replacement: 步骤 6 中的图像 1,2 ASUS GL752VW-DH74 Battery Replacement: 步骤 6 中的图像 2,2
    • Use the opening tool to pry the back of the laptop case from the top
    Note: carefully remove the back (bottom) lid and lift the front part first, as shown in the picture, as to not accidentally rip the cables connecting the motherboard to the keyboard.
    Also be aware that the lid often is somewhat glued in place, and the clip-on that holds the lid in place can easily break.
    Stig Kjørlaug - 回复
    In step 5 I noted that I removed 20 screws total. I was not able to pry off the keyboard until I did this. Be very careful and do not force it. I was not able to remove it with a spudger because it was too thick. A credit card worked well because it was thin and you could slide it carefully along the plastic clips to safely disengage them from the case. Note that your credit card might be damaged in the process so use an expired one or a similar plastic card.
    snamjoshi - 回复
  7. ASUS GL752VW-DH74 Battery Replacement: 步骤 7 中的图像 1,1
    • Disconnect the 3 cables connecting the motherboard to the keyboard.
    Open the safety (lift/turn the black piece of plastic that is pinning the cables in place), and remove (gently pull) the cables from the motherboard (top in the picture).
    Stig Kjørlaug - 回复
    When reassembling, gently push the cable into its respective slot. Each cable has a white stripe on it that should line up parallel to a white border on the motherboard. Each slot also has a very delicate locking hinge that will secure the ribbon cable in place. One the white stripe and white border are lined up, you will need to close that hinge to secure the ribbon cable. Try testing your battery and keyboard before fully locking the keyboard back in place.
    snamjoshi - 回复
  8. ASUS GL752VW-DH74 Battery Replacement: 步骤 8 中的图像 1,1
    • Unscrew the two 8mm screws attached to the battery
  9. ASUS GL752VW-DH74 Battery Replacement: 步骤 9 中的图像 1,1
    • Disconnect the bundled cable connector and remove the battery.
结论
20等其他人完成本指南。
Maxwell Seibert
于10/27/17注册
885 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 的会员
UMASSD-ISAACSON-F17S1G3
3 名成员
创作了5篇指南
5条评论
Step3 Remove Screw next to the serial label in order to remove the disk tray.
Step 5 Hard Drive screws case screws have to also be removed in addition to the screw below the internal clock battery
Great Guide Thank you !!! - Battery Model for GL 752VW-dh51 A41N1501
KN-IL - 回复
Despite the few missing “unscrew” steps, it REALLY helped me. It took quite a bit longer than 20 min as I did not want to wreck something, but overall I could not have changed my battery without this guide. THANK YOU!
Vio Belc - 回复
Thank you for your help, I now know how to change the battery, I tried disconnecting and reconnecting it see if I would get any power at all but zip, I will look on Ebay to try and buy a battery for it but I hope it’s that as it was working fine then said battery had no charge when I always made sure it never ran out so not sure what the problem was, at first I thought it was the chord but wasn’t that as I changed it.
angel - 回复
I have added comments to steps 5, 6, and 7. The biggest piece of advice is just to make sure you have all 20 screws removed before trying to remove the keyboard (the guide does NOT mention all 20 of these screws). This might be more than necessary but I felt safer removing them than risking snapping one of the plastic clips that holds the keyboard in place.
snamjoshi - 回复
Dont forget to put the three screws back in the frame prior to putting the optical drive back in and dont forget to put the battery screws back in, other than that a great guide.
Iain Halliwell - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 105
总计 28,470
