跳转到主内容
ASUS GL752VW-DH74 Battery Replacement
你所需要的
  1. ASUS GL752VW-DH74 Battery Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Begin by putting the needle into the hole in the disk tray.
  2. ASUS GL752VW-DH74 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to help ease out the disk drive.
  3. ASUS GL752VW-DH74 Battery Replacement: 步骤 3 中的图像 1,1
    • Pull out disk tray entirely.
  4. ASUS GL752VW-DH74 Battery Replacement, Battery: 步骤 4 中的图像 1,2 ASUS GL752VW-DH74 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the 3 small screws located underneath the disk drive.
  5. ASUS GL752VW-DH74 Battery Replacement: 步骤 5 中的图像 1,2 ASUS GL752VW-DH74 Battery Replacement: 步骤 5 中的图像 2,2
    • Unscrew the nine remaining 8 mm Phillips-head screws on the back of the device.
  6. ASUS GL752VW-DH74 Battery Replacement: 步骤 6 中的图像 1,2 ASUS GL752VW-DH74 Battery Replacement: 步骤 6 中的图像 2,2
    • Use the opening tool to pry the back of the laptop case from the top
  7. ASUS GL752VW-DH74 Battery Replacement: 步骤 7 中的图像 1,1
    • Disconnect the 3 cables connecting the motherboard to the keyboard.
  8. ASUS GL752VW-DH74 Battery Replacement: 步骤 8 中的图像 1,1
    • Unscrew the two 8mm screws attached to the battery
  9. ASUS GL752VW-DH74 Battery Replacement: 步骤 9 中的图像 1,1
    • Disconnect the bundled cable connector and remove the battery.
结论
20等其他人完成本指南。
Maxwell Seibert
于10/27/17注册
885 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 的会员
UMASSD-ISAACSON-F17S1G3
3 名成员
创作了5篇指南
5条评论
Step3 Remove Screw next to the serial label in order to remove the disk tray.
Step 5 Hard Drive screws case screws have to also be removed in addition to the screw below the internal clock battery
Great Guide Thank you !!! - Battery Model for GL 752VW-dh51 A41N1501
KN-IL - 回复
Despite the few missing “unscrew” steps, it REALLY helped me. It took quite a bit longer than 20 min as I did not want to wreck something, but overall I could not have changed my battery without this guide. THANK YOU!
Vio Belc - 回复
Thank you for your help, I now know how to change the battery, I tried disconnecting and reconnecting it see if I would get any power at all but zip, I will look on Ebay to try and buy a battery for it but I hope it’s that as it was working fine then said battery had no charge when I always made sure it never ran out so not sure what the problem was, at first I thought it was the chord but wasn’t that as I changed it.
angel - 回复
I have added comments to steps 5, 6, and 7. The biggest piece of advice is just to make sure you have all 20 screws removed before trying to remove the keyboard (the guide does NOT mention all 20 of these screws). This might be more than necessary but I felt safer removing them than risking snapping one of the plastic clips that holds the keyboard in place.
snamjoshi - 回复
Dont forget to put the three screws back in the frame prior to putting the optical drive back in and dont forget to put the battery screws back in, other than that a great guide.
Iain Halliwell - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 150
总计 28,932
