跳转到主内容
加入维修社区 - 创建账户
ASUS G713RC RAM Replacement
你所需要的
  1. ASUS G713RC RAM Replacement, RAM: 步骤 1 中的图像 1,3 ASUS G713RC RAM Replacement, RAM: 步骤 1 中的图像 2,3 ASUS G713RC RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Warning: Do not touch any other components inside if you don't have to. It may result in damage and can destroy your laptop.
    • Remove the seven large screws using a Phillips #00 screwdriver.
    • Remove the four small screws using a Phillips #00 screwdriver.
    • Carefully lift the lid, being careful of the two cables connected to the laptop.
  2. ASUS G713RC RAM Replacement: 步骤 2 中的图像 1,3 ASUS G713RC RAM Replacement: 步骤 2 中的图像 2,3 ASUS G713RC RAM Replacement: 步骤 2 中的图像 3,3
    • Carefully detach the two white cables that are connected to the lid.
    • Set aside the lid.
  3. ASUS G713RC RAM Replacement: 步骤 3 中的图像 1,3 ASUS G713RC RAM Replacement: 步骤 3 中的图像 2,3 ASUS G713RC RAM Replacement: 步骤 3 中的图像 3,3
    • Carefully lift up each gray bar.
    • It is important that you don't completely remove the gray bar.
    • Remove the RAM.
  4. ASUS G713RC RAM Replacement: 步骤 4 中的图像 1,3 ASUS G713RC RAM Replacement: 步骤 4 中的图像 2,3 ASUS G713RC RAM Replacement: 步骤 4 中的图像 3,3
    • Insert each RAM stick under the gray bar. Push until you hear a click.
    • Hold down the gray bar to make sure it is flat and secure.
    • It might be a bit bumpy, but it is nothing to worry about.
  5. ASUS G713RC RAM Replacement: 步骤 5 中的图像 1,2 ASUS G713RC RAM Replacement: 步骤 5 中的图像 2,2
    • Reattach the lid by connecting the white wires to the base.
    • Plug in the white wires on both sides. You want to plug them in thoroughly, otherwise, your laptop won't turn on.
  6. ASUS G713RC RAM Replacement: 步骤 6 中的图像 1,2 ASUS G713RC RAM Replacement: 步骤 6 中的图像 2,2
    • Line up the lid to the laptop.
    • Tighten the seven large screws using a Phillips #00 screwdriver.
    • Tighten the four small screws using a Phillips #00 screwdriver.
终点
2等其他人完成本指南。
团队
CSU Los Angeles, Team 4-99, Harris Fall 2024 CSU Los Angeles, Team 4-99, Harris Fall 2024 的会员
CSULA-HARRIS-F24S4G99
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 64
总计 947
