你所需要的
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
Remove adesive strips.
Disconnect the battery connectors by carefully pulling down on them using a spudger or plastic opening tool.
Disconnect Touch Connectors using a spudger or plastic opener tool.
Disconnect the ZIF connectors holding the battery.
Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
Disconnect cable
Remove the two Philips #0 screws from the power management board
Remove Philips #0 screw
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
4等其他人完成本指南。
