你所需要的
Unscrew the screws and with a plastic prying tool remove the cover carefully
Remove the ducktape form the Wi Fi modul
Carefully lift up the black sticky holder, thats holds in space the cables
Unplug the cables very carefully
Carefully move them out of the way form the heatsink
Under the WiFi card you will find more of the cabel holder duck tape.
Carefully lift it up and pull out the fan cables
Unscrew the 8 screws which holds in place the heatsink
IMPORTANT: By removing the srews you should follow the numbers next to them!!
Start from 8 and then 7 ,6, 5, 4, 3, 2, 1
First check again the WiFi antenna cables that they are out of the way!!!
Carefully and slowly lift up the Heatsink starting form right side (if you see exactly whats on the picture)!!
Remove the old thermal paste carefully with aceton and a tissue. If you dont have aceton, you can use just a tissue.
Be careful apply only so many which is necessary!!! In my opinion always check your new paste for conductivity and choose the ones with no eletrical conductivity because if you accidentaly spary on the motherboard you are still safe!!!!
If the paste on the parts on the second picture are still elastic you dont need to replace them
Remove the screws
If its unplugged now you can remove the old Fan
If your new fan has a duck tape on its one side remove it
From the old fan you can find a sticky foam, remove it and place it on the new fan exactly the same way!!!
Before you plug it in REMEMBER the way it was under the wifi card
use the strong ducktape to fix in its place
after you placed the cables under the ducktape you can plug the fan in
Carefully place the heatsink in its place
Scew it done starting from 1 and the 2, 3, 4, 5, 6, 7, 8
Once you have the heatsink in its place drive the cables over the heatsink but under the duck tap (white and black cable)
Put the WiFi card in its place
Scew it down
And plug back the cables
Reapply the duck which was on the wifi card!!! Its really important if you have or you want to have a M.2 ssd
Now you are finished
Just put back the cover and screw it down with screws !!!! Watch out they are not the same length!!!
