跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
ASUS F550 RAM Replacement
你所需要的
  1. ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: 步骤 1 中的图像 1,2 ASUS F550 RAM Replacement, ASUS F550 HDD/Ram Cover Removal: 步骤 1 中的图像 2,2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 RAM Replacement, Remove Ram: 步骤 2 中的图像 1,2 ASUS F550 RAM Replacement, Remove Ram: 步骤 2 中的图像 2,2
    • Release securing arms and remove RAM.
结论
另外一个人完成了本指南。
Ryan
于08/19/15注册
1,414 声望
创作了14篇指南
3条评论
Pretty sure only 2 of the 4 screws need to be removed.
tobiaskuhn - 回复
Can confirm only two screws required removal to enable access on my model F550C
Have successfully replaced HD once, but had slight issue getting it recognised
which is more of a BIOS issue, helps if you have a seperate bootable USB drive
but once recognised and OS installed, have several times swapped between the two
HDs (one Win8, one Linux - eventually plan to only use linux on this system).
Regards
Mike.
mihaly_k - 回复
Yes only two need to be removed, however I initially wrote a tear down to gain access to the network card etc and the way ifix it is structured for guide creation these steps are in fact used in that longer guide. I've amended the instructions now so hopefully they are more clear now.
Ryan -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 4,315
