跳转到主内容
ASUS F550 HDD Replacement
你所需要的
  1. ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: 步骤 1 中的图像 1,2 ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: 步骤 1 中的图像 2,2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 HDD Replacement, HDD: 步骤 2 中的图像 1,1
    • Remove 3 5mm Phillips screws
    • Slide HDD caddy back, remove using the black pull tab.
  3. ASUS F550 HDD Replacement, HDD Removal from Caddy: 步骤 3 中的图像 1,1
    • Remove 4 Phillips screws, 2 per side
    • Remove HDD from caddy.
结论
5等其他人完成本指南。
Ryan
于08/19/15注册
1,414 声望
创作了14篇指南
一条评论
What is the spec of the hard drive? SATA 2.5"? Any max capacity or other restrictions on what drops in?
mrgilbe1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 6,210
