跳转到主内容
ASUS Eee Pad Transformer GPS Antenna Replacement
你所需要的
  1. ASUS Eee Pad Transformer GPS Antenna Replacement, Back Panel: 步骤 1 中的图像 1,2 ASUS Eee Pad Transformer GPS Antenna Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 2 中的图像 1,3 ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 2 中的图像 2,3 ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 2 中的图像 3,3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 3 中的图像 1,1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 6 中的图像 1,2 ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 6 中的图像 2,2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: 步骤 7 中的图像 1,3 ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: 步骤 7 中的图像 2,3 ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: 步骤 7 中的图像 3,3
    • Remove the GPS antenna using the spudger.
  8. ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 8 中的图像 1,3 ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 8 中的图像 2,3 ASUS Eee Pad Transformer GPS Antenna Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to disconnect the two wires.
    • Remove the GPS Antenna from the device.
结论
Rillian Dennis
于11/06/19注册
202 声望
创作了2篇指南
团队
IUPUI, Team S1-G5, Harley Fall 2019 IUPUI, Team S1-G5, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S1G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 159
