跳转到主内容
ASUS Eee Pad Transformer Buttons Replacement
你所需要的
  1. ASUS Eee Pad Transformer Buttons Replacement, Back Panel: 步骤 1 中的图像 1,2 ASUS Eee Pad Transformer Buttons Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Buttons Replacement: 步骤 2 中的图像 1,3 ASUS Eee Pad Transformer Buttons Replacement: 步骤 2 中的图像 2,3 ASUS Eee Pad Transformer Buttons Replacement: 步骤 2 中的图像 3,3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Buttons Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Buttons Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Buttons Replacement: 步骤 6 中的图像 1,2 ASUS Eee Pad Transformer Buttons Replacement: 步骤 6 中的图像 2,2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Buttons Replacement, Remove button screws: 步骤 7 中的图像 1,2 ASUS Eee Pad Transformer Buttons Replacement, Remove button screws: 步骤 7 中的图像 2,2
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the buttons to the back panel.
  8. ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: 步骤 8 中的图像 1,3 ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: 步骤 8 中的图像 2,3 ASUS Eee Pad Transformer Buttons Replacement, Locate and lift button clip: 步骤 8 中的图像 3,3
    • Use Plastic Opening Tool to pry off the clip located towards the bottom of the button component near the metallic strip with a blue end, capped by the black button clip.
    • Remove button component by pulling straight outward from the device.
结论
3等其他人完成本指南。
Joe Payne
于09/29/14注册
537 声望
撰写一个指南
团队
Cal Poly, Team 13-9, Forte Fall 2014 Cal Poly, Team 13-9, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G9
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 6,753
