跳转到主内容
ASUS Eee Pad Transformer Back Panel Replacement
你所需要的
  1. ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Back Panel Replacement: 步骤 2 中的图像 1,3 ASUS Eee Pad Transformer Back Panel Replacement: 步骤 2 中的图像 2,3 ASUS Eee Pad Transformer Back Panel Replacement: 步骤 2 中的图像 3,3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Back Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Back Panel Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Back Panel Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Back Panel Replacement: 步骤 6 中的图像 1,2 ASUS Eee Pad Transformer Back Panel Replacement: 步骤 6 中的图像 2,2
    • Remove back panel by pulling away from the remaining device.
结论
4等其他人完成本指南。
Sandy Babich
于09/23/14注册
1,909 声望
创作了5篇指南
团队
Cal Poly, Team 13-9, Forte Fall 2014 Cal Poly, Team 13-9, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G9
5 名成员
创作了12篇指南
1指南评论
what can I use to stick back the metalic edge?
Cathy Madzimure - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 20
总计 4,123
